06/07/2009: Forums Update (No big deal)
Started by Tristan, June 07, 2009, 11:38:44 AM
As you can see, it's been a loonnngg time since there was any activity outside of the forums.  And, this update...doesn't really change that too much.  We're still alive though.
Anywho, the forums are being updated as I type this.  Actually the old instance is being backed up, then the upgrade will commence.  If anything is quirky after the upgrade (should be done by noon today), post in this thread and I'll either fix it or roll back to the last version (hence the backup).
Alright...we should be okay at this point.  I did a quick breezethrough and saw no significant problem other than the forums being out of order (which I took care of).
I think there might be some problems with URLs if you've linked to boards and posts here, but...I'll try to take care of those.
Post in this thread if you have any issues.
