March 2011 Photos
Started by C40LF_2464, March 02, 2011, 04:49:06 PM
A couple from the 1st of March and the last week of February!
nice shots, you could take it a bit easy on the saturation tbh, but not bad
Here's mine from recent days (probably not any better, but here they are anyways)
my baby:
the first Orion VII to be rehabbed...2582!
2126's W/C lift got stuck
so 4229 was sent to cover that 10B run
Route 80...with extension to Greenbelt Station! (yes I am aware that some 80 trips interline to R3, not sure if it goes the other way around)
finally got this sucker
6601 at Takoma Station (photo is a bit blurry and grainy because I set my camera to shutter speed priority mode because it was too dark to do it on manual, doing that allows more light into the photo but always comes out grainy)
Two of the 6500s with the Landover Crush:
Nice pics George! I like the 6601 and 6167 shots! I know it seems like the sat on my photos is to much, i take my photos in different modes on my cam, then when i edit them sometimes they get darker, so i have to sat them up.
Hmm...if they get "darker", might I suggest fiddling with the brightness/contrast rather than the saturation?  If done the right way, the contrast can make things "pop" out a little bit without too much distortion.  Everything in moderation, after all! :)
Otherwise, they are great pictures!
Quote from: Flxible_Metro_8700 on March 05, 2011, 12:23:18 PM
Which modes are you using?  I find the saturation to be a bit much on some of them, though they are good photos.  Another suggestion, if I can offer it, is consider making your watermark a bit smaller and not putting it anywhere but the corners of the photo, some of the ones that are closer to the image center are distracting and take away from your work IMO.
Keep up the good work!  It is nice to see the photos of the DC area buses here, since I can't see them in person for the most part.
Nabinut
6214:
174C outside the international terminal:
176C:
Audio of 174C on Route 201:
http://www.youtube.com/watch?v=zoDLvfjyR24
Ride-On:
5727:
5709:
5817:
5932:
5836:
Ride-On 5811-DD50G/Voith D864.3:
http://www.youtube.com/watch?v=yX_yHorVPZg
from 2 days ago:
and the first 2600 rehab caught on camera! (2608 is also rehabbed, not sure which was first)
I love that last shot! you know what would be pretty sweet? going to Silver Spring and seeing 6461 there and 6462 on an S or 70 route and get side-by-side shots
Pics from Friday and today. Heading up to Boston. See yall later.
Friday pics
Today's pic. Only at BWI. Major Amtrak fail day so no DC pics
Bosuton no ashita o sansho shite kudasai (See you tomorrow in Boston ^_^).
This bus was on the X9, the sign said 79 Silver Spring Station but when I took the shot, for some reason, the destination isn't showing in the photo
Northern strategic on the 36. The trip was started on the bus stop at Penn and 6th NW, here it is leaving the Penn-7th stop
Looks like Montgomery strategics on the 79 is becoming very common these days...
DCAreaTransitFan
3018 on the 18G
New Flyer C40LFR
Noice! Finally someone got a shot of it. Ain't it adorable?
Nice catch. It would have been better if they had let that white stripe go through. It just doesn't look right the way it currently is.
